How to mesh a 2D model with ultra huge length-width ratio?
I suppose to mesh a model which is a rectangle with 0.5nm width and 60um length. In width direction only one mesh is OK. Is there some good idea to deal with it?
Thanks a lot!
WU Han
1 Reply Last Post 2 feb 2016, 09:01 GMT-5
Posted: 9 years ago 2 feb 2016, 09:01 GMT-5
I suggest that you modify your geometry by scaling the other dimension by some appropriate length, let's call it L. Then when you have a derivative (say) du/dx you convert it to du/dz where z = x/L. This scaling has to be taken into account in the interpretation of the results, or by modifying appropriate constants. You did not disclose your physics, but if it were, for example, electrostatics you devide the conductivity by L in x direction. Like this:
k*(du/dx) = (k/L)*(du/dz).
Wish this helps. More hints you can find in the database.
BR
Lasse
Hi I suggest that you modify your geometry by scaling the other dimension by some appropriate length, let's call it L. Then when you have a derivative (say) du/dx you convert it to du/dz where z = x/L. This scaling has to be taken into account in the interpretation of the results, or by modifying appropriate constants. You did not disclose your physics, but if it were, for example, electrostatics you devide the conductivity by L in x direction. Like this: k*(du/dx) = (k/L)*(du/dz). Wish this helps. More hints you can find in the database. BR Lasse
