17 ott 2010, 05:08 GMT-4
for me if you fix a temperature, then you ask COMSOL to adapt the heat flux such to maintain the temperature, therefore you cannot also add a heat flux.
But you can always consider the heat flux COMSOL finds it needs to control the temperature, and offset this value by your fixed value if you that makes more sens for you.
I believe the same applies to your second question too. I do not really catch the physical sens of what you are asking for
Roopesh Mohandas Syamaladevi
17 ott 2010, 15:58 GMT-4
Sorry, I did not quite understand your reply. In my coupling model, in the air-food interface, I can select continuity, temperature or flux discontinuity. The BC are heat flux continuity and temperature continuity. A latent heat term is involved in the heat flux continuity expn. If I select temperature as my BC, where I will express the heat flux continuity in Comsol? please see the attachment for the BCs.
Could you please explain this?
18 ott 2010, 02:08 GMT-4
In v3.5 all fields are shown but some might not be changed (greyed) due to the BC you select:
continuity means the normal flux is matched (internally by COMSOL nothing to do)
Temperature means you decide the Temperature, but nothing else (others are greyed) etc
21 ott 2010, 11:18 GMT-4
Thank you Ivar for your help. I figured it out.
Roopesh
Roopesh
29 nov 2010, 04:48 GMT-5
Hi Roopesh,
Can you please tell me how u did it??
I mean: temperature continuity and heat flux @ a boundary
Ganesh Samdani
Hi Roopesh,
Ganesh Samdani
29 nov 2010, 10:19 GMT-5
Actually I did not continue the model the way I described in the question. But i can suggest you to make two physics for each sub domain. for instance, make one heat transfer and mass transfer physics for one sub domain and let it be active in that domain. Let this heat and mass transfer physics not active in the other sub domain. Similarly add another heat and mass transfer physics for the second sub domain and let it be not active in the first sub domain. Now you get the needed BCs.
Hope this helps.
Roopesh
Hope this helps.
Roopesh
