Asymmetric strain with symmetric materials, geometry and load. Where is the problem?
Posted 12 feb 2016, 02:14 GMT-5 Geometry, Materials, Modeling Tools & Definitions, Parameters, Variables, & Functions, Structural Mechanics Version 4.4, Version 5.2, Version 5.2a, Version 5.3 5 Replies
I modeled a round diaphragm (a thin disk) in Comsol 4.4 with two different materials: one isotropic and the other anisotropic. For the latter I will need to explore different crystal cuts, therefore I defined a rotated system for the material. The boundary conditions I am applying are:
1. prescribed displacement on the bottom edge (displacement 0 in all directions)
2. a certain pressure on the backside surface
The problems start already with the isotropic material: if the displacement is invariant with respect to an arbitrary in-plane rotation, the strain is not. I need to evaluate the engineering strain (relative increase/decrease of the distances) at the top surface in the normal directions (no shear). I am therefore evaluating the Strain tensor (Material): solid.eXX, solid.eYY. According to Comsol Reference Guide this should be the correct one. Am I right?
What disturbes me is that sqrt(solid.eXX^2+solid.eYY^2) is not invariant with respect to an arbitrary in-plane orientation, even for the isotropic material. So either I am programming something wrong, or I am evaluating the wrong variables, as the strain in the radial direction has to reflect the symmetry of the object if the material and the load are isotropic.
Thank you very much.
5 Replies Last Post 18 feb 2016, 11:03 GMT-5
