Volume Integration of revolution 2D
2D axisymmetry
The geometry is a rectangle
Right-click Data sets, and choose Revolution 2D, set revolution angle as 360 deg
Right-click Derived values, and choose Volume Integration, set Expression as 1, then Click the button " = "
It was expected to obtain the volume, but an error happened "Cannot evaluate expression"
What's the problem?
7 Replies Last Post 8 apr 2011, 08:12 GMT-4
Posted: 1 decade ago 22 ott 2010, 15:46 GMT-4
if you are in 2D axi how can you get a volume ? are you in 3.5 ? then be sure you integrate on the right "volume"/geoemtry
Hi if you are in 2D axi how can you get a volume ? are you in 3.5 ? then be sure you integrate on the right "volume"/geoemtry -- Good luck Ivar
Posted: 1 decade ago 22 ott 2010, 20:50 GMT-4
My comsol version is 4.0
In postprocessing, i.e. the Results, I right-click Data sets, and choose Revolution 2D, then set the parameters in the Revolution 2D interface, Axis entry method = two points, Revolution angle = 360 deg, then I can get the volume (a cylinder)
[QUOTE] Hi if you are in 2D axi how can you get a volume ? are you in 3.5 ? then be sure you integrate on the right "volume"/geoemtry -- Good luck Ivar [/QUOTE] My comsol version is 4.0 In postprocessing, i.e. the Results, I right-click Data sets, and choose Revolution 2D, then set the parameters in the Revolution 2D interface, Axis entry method = two points, Revolution angle = 360 deg, then I can get the volume (a cylinder)
Posted: 1 decade ago 23 ott 2010, 04:06 GMT-4
OK now I understand your are in the Postprocessing, I was searching in the "Geometry" as there too you can generate "revolved" geoemtry in 3D from 2D.
I will have to try it out, I have only used this function so far for visualisation. Normally you integrate a volume fromn 2D axi with a 2*pi*r the "loop length", but there is also the click box in some of the advanced features (not everywhere though) and between 3.5 and 4 there is a 2*pi change. I never remember so I always check by hand the eqautions behind and a simple numerical test, to be sure ;)
Hi OK now I understand your are in the Postprocessing, I was searching in the "Geometry" as there too you can generate "revolved" geoemtry in 3D from 2D. I will have to try it out, I have only used this function so far for visualisation. Normally you integrate a volume fromn 2D axi with a 2*pi*r the "loop length", but there is also the click box in some of the advanced features (not everywhere though) and between 3.5 and 4 there is a 2*pi change. I never remember so I always check by hand the eqautions behind and a simple numerical test, to be sure ;) -- Good luck Ivar
Posted: 1 decade ago 23 ott 2010, 10:42 GMT-4
Thanks Ivar, but why I cannot get the volume using "Volume Integration"? However, there is a sentance "Make a volume integration of a 2D revolve" in COMSOL Multiphysics>Results analysis and plot features>Derived values and tables (the help document)
[QUOTE] Hi OK now I understand your are in the Postprocessing, I was searching in the "Geometry" as there too you can generate "revolved" geoemtry in 3D from 2D. I will have to try it out, I have only used this function so far for visualisation. Normally you integrate a volume fromn 2D axi with a 2*pi*r the "loop length", but there is also the click box in some of the advanced features (not everywhere though) and between 3.5 and 4 there is a 2*pi change. I never remember so I always check by hand the eqautions behind and a simple numerical test, to be sure ;) -- Good luck Ivar [/QUOTE] Thanks Ivar, but why I cannot get the volume using "Volume Integration"? However, there is a sentance "Make a volume integration of a 2D revolve" in COMSOL Multiphysics>Results analysis and plot features>Derived values and tables (the help document)
Posted: 1 decade ago 24 ott 2010, 14:36 GMT-4
well I get a volume integrsation of the revolved volume by 1, and by the integration of 2*pi*r (via the volume integration check for 2D axi) and via the surface integration of "2*pi*r" the expression written out explicitely (see the table
Hi well I get a volume integrsation of the revolved volume by 1, and by the integration of 2*pi*r (via the volume integration check for 2D axi) and via the surface integration of "2*pi*r" the expression written out explicitely (see the table -- Good luck Ivar
Posted: 1 decade ago 24 ott 2010, 19:43 GMT-4
Thank you very much, Ivar! But when I try to open the file VolInt1.mph, an error happened "File contains no model", I don't know why. My COMSOL is version 4.0.
[QUOTE] Hi well I get a volume integrsation of the revolved volume by 1, and by the integration of 2*pi*r (via the volume integration check for 2D axi) and via the surface integration of "2*pi*r" the expression written out explicitely (see the table -- Good luck Ivar [/QUOTE] Thank you very much, Ivar! But when I try to open the file VolInt1.mph, an error happened "File contains no model", I don't know why. My COMSOL is version 4.0.
Tom Alexander Solgård
Posted: 1 decade ago 8 apr 2011, 08:12 GMT-4
Thanks for this demo-model, Ivar! It really helped me out.
MSc. Acoustics using COMSOL for modelling loudspeakers and room acoustics.
no.linkedin.com/pub/tom-alexander-solg%C3%A5rd/27/600/1b3
[QUOTE] Hi well I get a volume integrsation of the revolved volume by 1, and by the integration of 2*pi*r (via the volume integration check for 2D axi) and via the surface integration of "2*pi*r" the expression written out explicitely (see the table [/QUOTE] Thanks for this demo-model, Ivar! It really helped me out. -- MSc. Acoustics using COMSOL for modelling loudspeakers and room acoustics. http://no.linkedin.com/pub/tom-alexander-solg%C3%A5rd/27/600/1b3
