COMSOLPIN photodiode example simulation (updated)
Hi, i'm trying to do a photodiode simulation based on the gaas PIN diode example from comsol. In this example, the electromagnetic wave is excited from port1 and port 2 at the semiconductor boundary, with uniform electric field. I made a slight change to the example. Instead of exciting a uniform wave at port 1, now i'm exciting it with a Gaussian field distribution, i.e, Ez=exp(-(x/1000[nm])^2). I've also made some change to the meshing(which works fine if the excitation is uniform). However, i'm getting this error:
Attempt to evaluate negative power of zero.
- Function: ^
Failed to evaluate temporary symbolic derivative variable.
- Variable: comp1.ewfd.normE@VDN${realdot@2}
- Defined as: (0.5*((realdot(comp1.ewfd.Ez,comp1.ewfd.Ez)+(realdot(comp1.ewfd.Ex,comp1.ewfd.Ex)+realdot(comp1.ewfd.Ey,comp1.ewfd.Ey)))^(-0.5)))
- Variable: comp1.semi.Enorm0_wo@VDN${realdot@2}
- Defined as: ((0.5*((realdot(comp1.ewfd.Ez,comp1.ewfd.Ez)+(realdot(comp1.ewfd.Ex,comp1.ewfd.Ex)+realdot(comp1.ewfd.Ey,comp1.ewfd.Ey)))^(-0.5))))
- Expression: d(((comp1.semi.Enorm0_wo*unit_m_cf)/unit_V_cf),{realdot@2})
anyone has any idea what might be the cause? Thanks a lot!
3 Replies Last Post 22 feb 2017, 01:49 GMT-5
Posted: 9 years ago 9 mar 2016, 09:16 GMT-5
is the negative power of zero due to meshing, convergence, or some other reason?
Posted: 9 years ago 10 mar 2016, 12:41 GMT-5
any help would be appreciated, otherwise i probably will switch to TCAD altas to do this, which requires learning the new software...
Posted: 8 years ago 22 feb 2017, 01:49 GMT-5
- Function: ^
Please check initial values under Electromagnetic Waves, Frequency Domain study. I faced same problem due to zero (0) value under Electric field for x,y and z. This problem was solved using Ez=1
[QUOTE] Hi, i'm trying to do a photodiode simulation based on the gaas PIN diode example from comsol. In this example, the electromagnetic wave is excited from port1 and port 2 at the semiconductor boundary, with uniform electric field. I made a slight change to the example. Instead of exciting a uniform wave at port 1, now i'm exciting it with a Gaussian field distribution, i.e, Ez=exp(-(x/1000[nm])^2). I've also made some change to the meshing(which works fine if the excitation is uniform). However, i'm getting this error: Attempt to evaluate negative power of zero. - Function: ^ Failed to evaluate temporary symbolic derivative variable. - Variable: comp1.ewfd.normE@VDN${realdot@2} - Defined as: (0.5*((realdot(comp1.ewfd.Ez,comp1.ewfd.Ez)+(realdot(comp1.ewfd.Ex,comp1.ewfd.Ex)+realdot(comp1.ewfd.Ey,comp1.ewfd.Ey)))^(-0.5))) Failed to evaluate temporary symbolic derivative variable. - Variable: comp1.semi.Enorm0_wo@VDN${realdot@2} - Defined as: ((0.5*((realdot(comp1.ewfd.Ez,comp1.ewfd.Ez)+(realdot(comp1.ewfd.Ex,comp1.ewfd.Ex)+realdot(comp1.ewfd.Ey,comp1.ewfd.Ey)))^(-0.5)))) Failed to evaluate expression. - Expression: d(((comp1.semi.Enorm0_wo*unit_m_cf)/unit_V_cf),{realdot@2}) anyone has any idea what might be the cause? Thanks a lot! [/QUOTE] Please check initial values under Electromagnetic Waves, Frequency Domain study. I faced same problem due to zero (0) value under Electric field for x,y and z. This problem was solved using Ez=1
