Error during meshing
Kindly help me regarding this problem.
when i do the meshing then this error is generated.
Exception:
com.femlab.jni.FlNativeException: Internal error boundary respecting
Failed to respect boundary element edge on geometry face
- Face: 24
- x coordinate: -0.23185
- y coordinate: -0.006
- z coordinate: 0.24275
Failed to generate mesh for subdomain
- Subdomain: 2
Stack trace:
at delaunaytet.cpp, row 2373, ()
at delaunaytet.cpp, row 4841, ()
at mesh3init.cpp, row 3309, ()
at com.femlab.mesh.Mesh.init(Native Method)
at com.femlab.mesh.Mesh.init(Unknown Source)
at com.femlab.mesh.MeshInitRunnable.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.ae.run(Unknown Source)
1 Reply Last Post 28 ott 2010, 09:38 GMT-4
Posted: 1 decade ago 28 ott 2010, 09:38 GMT-4
I see/saw this error (far less in V4 though) when I was meshing complex geometries, typically when the mesher had meshed all but a few parts, surrounded by other meshed entities, then the last meshing had problems to create a coherent mesh in the last volumes.
To get around, try to use edge meshes as seed, mesh from inside/centre outwards, in several steps.
meshing is somewhat an art ... ;)
Hi I see/saw this error (far less in V4 though) when I was meshing complex geometries, typically when the mesher had meshed all but a few parts, surrounded by other meshed entities, then the last meshing had problems to create a coherent mesh in the last volumes. To get around, try to use edge meshes as seed, mesh from inside/centre outwards, in several steps. meshing is somewhat an art ... ;) -- Good luck Ivar
