Initial Pressure - error
Posted 21 mar 2016, 02:00 GMT-4 Fluid & Heat, Studies & Solvers Version 5.2 0 Replies
I try to model the influence of a heated boundary on surrounding air in a 3-d model. When I try to set the initial pressure in the laminar flow to:
-spf.rho*g_const*(0.05[m]-z)
I always get the following error message:
Error in user-defined function.
- Function: dcomp1.mat1.def.rho_drho__T__internalArgument
Failed to evaluate temporary symbolic derivative variable.
- Variable: comp1.ht.rho@VDN$comp1.T
- Defined as: (unit_kg_cf*(dcomp1.mat1.def.rho_drho__T__internalArgument(comp1.ht.fluid1.minput_pressure/unit_Pa_cf,comp1.ht.fluid1.minput_temperature/unit_K_cf)*(1/unit_K_cf)))*(1/(unit_m_cf^3))
- Variable: comp1.ht.C_eff@VDN$comp1.T
- Defined as: (((unit_kg_cf*(dcomp1.mat1.def.rho_drho__T__internalArgument(comp1.ht.fluid1.minput_pressure/unit_Pa_cf,comp1.ht.fluid1.minput_temperature/unit_K_cf)*(1/unit_K_cf)))*(1/(unit_m_cf^3)))*comp1.ht.Cp)+(comp1.ht.rho*((unit_J_cf*(dcomp1.mat1.def.Cp(comp1.ht.fluid1.minput_temperature/unit_K_cf)*(1/unit_K_cf)))*(1/(unit_K_cf*unit_kg_cf))))
- Expression: dvol*(comp1.ht.d*(comp1.Tt*(-((((unit_kg_cf*(dcomp1.mat1.def.rho_drho__T__internalArgument(comp1.ht.fluid1.minput_pressure/unit_Pa_cf,comp1.ht.fluid1.minput_temperature/unit_K_cf)*(1/unit_K_cf)))*(1/(unit_m_cf^3)))*comp1.ht.Cp)+(comp1.ht.rho*((unit_J_cf*(dcomp1.mat1.def.Cp(comp1.ht.fluid1.minput_temperature/unit_K_cf)*(1/unit_K_cf)))*(1/(unit_K_cf*unit_kg_cf))))))))
Failed to evaluate Jacobian of expression.
- Expression: dvol*(((-comp1.ht.C_eff)*comp1.Tt)*comp1.ht.d)
- Expression: (-comp1.ht.C_eff*comp1.Tt*test(comp1.T)*comp1.ht.d)*(dvol)
It would be great, if somebody could help me!!
Thanks a lot in advance! :D
Hello Matthias Auf der Mauer
