Problem with convergence of solution in 2D U shape Thermal Stress
Posted 30 mar 2016, 15:27 GMT-4 Structural Mechanics Version 5.2 2 Replies
I want to know how much deflection at some point in my structure in "Thermal Stress" module
So from the beginning, I chose 2D Structure Mechanics - Thermal stress, and stationary as physics.
I defined geometry (in micrometers), just four rectangular domains connected together, making something like "U" shape.
Then I defined material, polysilicon(default)
Next is considering boundary conditions and initial values.
For defining "Solid Mechanics", I created - "Fixed constraint" and I fixated 2 ends. of "U"
For "Heat transfer in Solids", I created - "Heat source" and chose "Overall heat transfer rate" 1mW in one domain. - I did this for assuming that a heating power of 1mW is uniformly dissipated along that domain.
Also, I did not forget to define all the thickness for 'Solid mechanics' and 'Heat transfer in solid', and choose "plane stress"
I created mesh, normal size for first.
Now, I clicked study.
However, I get this message
"Failed to find a solution
The relative residual (3.5) is greater than the relative tolerance.
- feature: Stationary Solver 1 (sol1/s1)"
Am I missing something?
2 Replies Last Post 31 mar 2016, 08:21 GMT-4
