"unit syntax error"
In "Global Definitions --- Parameters", the value of Volume (V) is known, I input "(3*V/(4*pi))^(1/3)" to calculate the Radius (R) of the Sphere, but an error happens, i.e. "unit syntax error". Why? Cannot use "^(1/3)" in comsol?
2 Replies Last Post 3 nov 2010, 09:55 GMT-4
Magnus Ringh COMSOL Employee
Posted: 1 decade ago 3 nov 2010, 05:09 GMT-4
This works in version 4.0a, so I assume that you are using version 4.0.
The unit syntax in COMSOL Multiphysics treats units with integer exponents. Fractional exponents like 1/3 do work, however, if the "composite exponents" for the unit in the expression are integers (in this case, m^(3/3) = m).
Magnus Ringh, COMSOL
Hi, This works in version 4.0a, so I assume that you are using version 4.0. The unit syntax in COMSOL Multiphysics treats units with integer exponents. Fractional exponents like 1/3 do work, however, if the "composite exponents" for the unit in the expression are integers (in this case, m^(3/3) = m). Best regards, Magnus Ringh, COMSOL
Posted: 1 decade ago 3 nov 2010, 09:55 GMT-4
Thanks!
Yes, I use version4.0. So we cannot use "^(1/3)", i.e. the fractional expoent, in version 4.0, right?
[QUOTE] Hi, This works in version 4.0a, so I assume that you are using version 4.0. The unit syntax in COMSOL Multiphysics treats units with integer exponents. Fractional exponents like 1/3 do work, however, if the "composite exponents" for the unit in the expression are integers (in this case, m^(3/3) = m). Best regards, Magnus Ringh, COMSOL [/QUOTE] Thanks! Yes, I use version4.0. So we cannot use "^(1/3)", i.e. the fractional expoent, in version 4.0, right?
