Inductance of helical core with and without iron core
Posted 5 apr 2016, 07:06 CEST Low-Frequency Electromagnetics Version 5.2 4 Replies
Hi all,
I'm trying to create an inductor at a given uH, using the mef-module and applying voltage at a terminal in one end of the helix and applying ground at the opposite end.
Using the built-in value I can retrieve the inductance: mef.L11.
Let'a say that for a small mm-sized helix with 10 turns and air core I get 0.03 uH.
I would then expect to have a much higher inductance when placing a sylindrical iron core in the center of the helix, but the result is still the same (i have tried with and without applying the ground boundery to the iron core).
How to get COMSOL to "use" the iron core to boost the indutance?
I also wonder why I get "not applicable" on the helix end-bounderies when assigning ground and terminal when the entire model is inside a sphere of air.
4 Replies Last Post 7 apr 2016, 09:09 CEST
