Derived Value Slower, Less Accurate than Plot
I am trying to find the minimum value of a function evaluated only on a subset of a given surface, where that subset is specified by a constraint.
I've defined a minimum derived value, and given an expression of the form:
myfunction(params) + (mycondition==0)*largenumber
This way, unless mycondition is met, the expression won't come close to the minimum value, so I restrict attention to the aforementioned subset of interest.
Now, here's the rub- when I calculate the derived value, it takes a full minute, then returns a minimum value that is greater than largenumber. BUT, when I do an isosurface plot of my data set, colored with the expression above, it evaluates in 10 seconds and I can clearly see with my eye that the minimum is much less than largenumber (because there ARE regions where my condition is met) and what the derived minimum value was returning cannot be correct.
Why would plotting my expression on the surface of interest be so much faster than finding the minimum value on that surface? Why is the minimum value calculation way off?
Should I just make plots for all of my parameters of interest and use the minimum value on the color bar to get what I want? Seems like a silly way that shouldn't be more efficient and accurate than the derived value approach, but here I am.
0 Replies Last Post 5 apr 2016, 10:56 GMT-4
Hello David Reens
