Electromagnetic (Optical) heating
I have a model in which I want to study the induced heat due to absorption of waves in the range of optical frequencies. As the minimum dimensions of my model are near the wavelenths, I am using microwave heating under heat transfer in solids module (electromagnetic waves frq domain+heat transfer in solids).
My question is that which subnode I can use for the absorption of waves at the surface of my model (which is metallic in this case). There is a subnode called "port" under electromagnetic waves but I don't think that can be used for metallic boundary and even if I use that port to define the input power of radiation, the simulation shows a very very high temperature which is not possible.
So, if anybody is working with radiation heating etc and have some idea which type of interface can be used, I would appreciate the help. Thanks
~Hasan Ali
2 Replies Last Post 12 apr 2016, 04:15 GMT-4
Niklas Rom COMSOL Employee
Posted: 9 years ago 7 apr 2016, 09:54 GMT-4
Hi Hassan,
the Impedance boundary condtion is probably the best choice. There is a blog post about this here:
www.comsol.com/blogs/modeling-metallic-objects-in-wave-electromagnetics-problems/
kind regards
Niklas
~Hasan Ali
Hi Hassan, the Impedance boundary condtion is probably the best choice. There is a blog post about this here: https://www.comsol.com/blogs/modeling-metallic-objects-in-wave-electromagnetics-problems/ kind regards Niklas [QUOTE] Hi, I have a model in which I want to study the induced heat due to absorption of waves in the range of optical frequencies. As the minimum dimensions of my model are near the wavelenths, I am using microwave heating under heat transfer in solids module (electromagnetic waves frq domain+heat transfer in solids). My question is that which subnode I can use for the absorption of waves at the surface of my model (which is metallic in this case). There is a subnode called "port" under electromagnetic waves but I don't think that can be used for metallic boundary and even if I use that port to define the input power of radiation, the simulation shows a very very high temperature which is not possible. So, if anybody is working with radiation heating etc and have some idea which type of interface can be used, I would appreciate the help. Thanks ~Hasan Ali [/QUOTE]
Posted: 9 years ago 12 apr 2016, 04:15 GMT-4
Dear Niklas,
Thanks for your suggestions.
Regards
Hasan Ali
Dear Niklas, Thanks for your suggestions. Regards Hasan Ali
