problems with OpenGL and DirectX
Posted 8 nov 2010, 11:25 GMT-5 Installation & License Management Version 4.1, Version 5.0, Version 5.2 12 Replies
AMD II X2 2.0 GHz (dual-core)
ATI Mobility Radeon 4200 256 Mb
4 Gb RAM
DirectX 11 is installed, and as I've understood, it should be backward compatible with DirectX 9 which is supported by COMSOL. Has anyone encountered similar problems or is there a solution for this kind of problem? Since I only have a student license, the COMSOL support cannot help me with this problem.
I am affraid that short of getting a new laptop [ not sure changing the video card is worth it on a laptop] AND testing it works with comsol before paying for it... there is not a lot of options out there..
but i will be delighted to be proven wrong
also I have ZERO experience with windows 7 ..as stated above this was a linux worstation...
bottom line opengl is not such a clean standard as it looks like apparently that ..[ I am NOT an expert on this but I suffered the pain of SLOOOOOOW software rendering too.
JF
Hardware: Dell T7500, 96GB RAM, Nvidia Quadro 5000(driver:latest version)
However, when OpenGL is selected, the graphic windows shows black background only so that I couldn't do anything since opened models are not seen.
DirectX seems OK.
Currently, I have no time to see my problem in detail.
Soon, I will checkit again, and say the status again.
and i am having the same problems!!
Does anyone have a solution?
Thank you,
But OpenGL doesn't work yet in Windows 7.
Recently, I additionally installed Ubuntu 10.10 version in the same computer.
Windows7 and Ubuntu10.10 runs OK without problem.
COMSOL linux version also works good with OpenGL option in Ubuntu using trial license obtained from my software agent.
So, I am planning to tranfer to Ubuntu Linux for COMSOL since my first 1 year warranty period is not ended.
Though Ubuntu is not officially supported by COMSOL, it's easy to use and no problem in my computer.
there must be adriver issue, I have no problems on my CetOS-V / Win 7 dual boot Intel based workstation
I am in the process of accuiring a new laptop for my work. Could you indicate what type of brand the laptop is and which graphics card is installed?
Henk van Weers
SRON
it's not a laptop, in my case its an Intel based board (S5520SCR) workstation with two X5680 cpus and a 1kW power supply (a real helocopter when it really starts to work ;) and a Nvidia Quadro FX1800 graphics cad and two 24" screens. Operating in dial boot Win-7 and Centos 5, depending if we need Solidworks or not ;)
New latest version driver works OK using OPENGL.
Do this.
1) File
2) Preference
3) Graphics and plot windows
4) Visualization
5) Rendering, Change form openGL to Dirext X9
Solved.
Tried two versions, 5.0 and 5.2 Both worked!
Now, it is perfectly working
Suggested Content
- BLOG Nonlinearity Ramping for Improving Convergence of Nonlinear Problems
- KNOWLEDGE BASE Avoiding Negative Concentrations
- KNOWLEDGE BASE Understanding the Fully Coupled vs. Segregated approach and Direct vs. Iterative Linear Solvers
- KNOWLEDGE BASE How does COMSOL Multiphysics handle complex-valued numbers and problems in the frequency domain?
- BLOG Learning to Solve Multiphysics Problems Effectively
