Cluster and several jobs with just on licence
Jean-Christophe Lavocat
Dear all,
Here is my problem : we have a cluster, and a licence for cluster jobs, which means for parallel computation on our grid. But today I wanted to launch two different jobs on two different nodes, and Comsol told me that I have only one licence (and not two).
I could understand that when I was working on my local computer and as the same time on the grid. But now the two versions are open on the grid, so I should b able to open them together.
Any idea on how to solve it?
ps : I launch the solving process like this :
I connect to the first node via ssh, then comsol batch my file. I let it run while I connect to the second node via ssh. I try comsol batch, but this one doesn't launch because of this problem of licence.
2 Replies Last Post 9 nov 2010, 04:39 GMT-5
Posted: 1 decade ago 9 nov 2010, 04:20 GMT-5
I had heard the same, and that's why I didn't buy the cluster license.
You can run as many simulations on ONE running comsol, and even if you have 300 CPUs you can not have 10 comsol instances x30 CPUs running.
That's a pity.
ps. I hope I got your question right.
Comsol 4.0a
Ubuntu 10.04.1
I had heard the same, and that's why I didn't buy the cluster license. You can run as many simulations on ONE running comsol, and even if you have 300 CPUs you can not have 10 comsol instances x30 CPUs running. That's a pity. ps. I hope I got your question right. -- Comsol 4.0a Ubuntu 10.04.1
Posted: 1 decade ago 9 nov 2010, 04:39 GMT-5
Yeap, you got it right.
That's also a pity because I couldn't use the grid as I should. Comsol never manages to solve the solution properly if I use it on the grid.
Yeap, you got it right. That's also a pity because I couldn't use the grid as I should. Comsol never manages to solve the solution properly if I use it on the grid.
