9 years ago
27 apr 2016, 12:43 GMT-4
it depends how you see your model: normally one think a beam "fixed" to an object being accelerated (where is the absolute inertial frame ?), but one can turn it around and say a beam absolutely "fixed", undergoing a body load (type gravity acceleration) of known amplitude or random average amplitude scanned over a frequency.
But if you apply a acceleration to an object "fixed" then you ask for an impossibility at the "fixed region". Furthermore, if you apply a 1/2 sine shock acceleration impulse to an object, it will continue to "fly" away at constant speed once the impulse is over, for such a case you cannot "fix" it but probably using the traditional "big mass" approach to attach the object to a large mass and accelerate the large mass (with your small beam attached), at a Force amplitude corresponding to the sum of both masses.
"There are many ways to Rome", for acceleration loads too, but some are simpler to model than others, all depends what exactly you are looking for ;)
9 years ago
28 apr 2016, 00:09 GMT-4
Hey Ivar! I am working on a Cantilever which is fixed from one side. I want to apply acceleration on whole body from Z direction. How can I do that?
