Best Way to Incident Electric Field
I'm currently working on modeling a 2D gradient index metamaterial lens and studying the electric field intensity inside it. My geometry consists of vertical alternating layers of two different materials (Ag and Alumina) and I have to incident a plane wave from the top of the resulting rectangle and study the x-component of the resultant electric field intensity inside the lens. I've used port excitation, surface current, initial electric field at the upper boundary (which is also surrounded by a PML) but I can't seem to get my results. I'm 100% sure my geometry and physics are correct, so this definitely has something to do with my physics. Can anyone help me out with this? :)
1 Reply Last Post 8 mag 2016, 22:18 GMT-4
Posted: 8 years ago 8 mag 2016, 22:18 GMT-4
You may want to try calculation of scattered field, where you can specify incident wave by expression input.
Pu, ZHANG
DTU Fotonik
You may want to try calculation of scattered field, where you can specify incident wave by expression input. -- Pu, ZHANG DTU Fotonik
