Different excitation loads in Frequency Response Analysis
Please, is it possible to assign different boundary loads to different excitation frequencies when using Frequency Response Aanlysis? At present all I am ble to do is apply a single load at multiple frequencies.
Many thanks
3 Replies Last Post 3 ago 2011, 17:18 GMT-4
Posted: 1 decade ago 16 nov 2010, 09:52 GMT-5
I have never tried it, but why not: normally the frequency sweep name is "freq" so why not use it to express a BC and test it out, take a simple case you are sure to understand.
And pls report back, interesting question ;)
Hi I have never tried it, but why not: normally the frequency sweep name is "freq" so why not use it to express a BC and test it out, take a simple case you are sure to understand. And pls report back, interesting question ;) -- Good luck Ivar
Posted: 1 decade ago 16 nov 2010, 13:23 GMT-5
No luck with the 'freq' command in the BC, even for a single load and single frequency. I only get results with a load value.
If you manage to get a solution, pls let me know.
Many thanks
Hi, No luck with the 'freq' command in the BC, even for a single load and single frequency. I only get results with a load value. If you manage to get a solution, pls let me know. Many thanks
Posted: 1 decade ago 3 ago 2011, 17:18 GMT-4
I am wondering if you got to solve your problem.
I am trying to model a pressurized pipe with a point load that acts as a source of vibration. I am not able to apply the pressure without the solver considering both the pressure and point load to be vibration sources.
Angel Suresh
Hi, I am wondering if you got to solve your problem. I am trying to model a pressurized pipe with a point load that acts as a source of vibration. I am not able to apply the pressure without the solver considering both the pressure and point load to be vibration sources. Thanks, Angel Suresh
