Postprocessing and visualization
Maria de Fátima Lopes Leite
How can I plot in a self-defined function instead a cut line within a 3D model?
3 Replies Last Post 25 mag 2016, 11:01 GMT-4
Posted: 9 years ago 16 mag 2016, 02:08 GMT-4
You can use a 3D parameterized curve data set.
[QUOTE] How can I plot in a self-defined function instead a cut line within a 3D model? [/QUOTE] You can use a 3D parameterized curve data set.
Posted: 9 years ago 25 mag 2016, 10:13 GMT-4
Hi! Thanks for your answer.
I would like to plot on a point cloud that has no defined function and I'm not getting. It's possible?
Hi! Thanks for your answer. I would like to plot on a point cloud that has no defined function and I'm not getting. It's possible?
Posted: 9 years ago 25 mag 2016, 11:01 GMT-4
Not in 4.2, but support for this was added in 5.1: You can create a cut point data that points to a file containing the coordinates and use it in a Point Trajectories plot with a Color Expression attribute.
[QUOTE] Hi! Thanks for your answer. I would like to plot on a point cloud that has no defined function and I'm not getting. It's possible? [/QUOTE] Not in 4.2, but support for this was added in 5.1: You can create a cut point data that points to a file containing the coordinates and use it in a Point Trajectories plot with a Color Expression attribute.
