coupled_line_microwave_filter_simulation
Posted 16 nov 2010, 11:46 GMT-5 1 Reply
Hi all,
I am trying to simulate a coupled-line microstrip filter. I designed this filter using ADS and simulated
with ADS momentum and ADS FEM, both gave me reasonable response. The center frequency is around
34.0GHz. But I cannot get a right answer when I put it in COMSOL. The S12 has a peak at 31GHz only -40dB. Attached is the model file. I also tried a low frequency filter at 1GHz, and the simulation works. But the 34GHz filter doesn't work. I refined the mesh around the ports and transmission lines, but this didn't improve the result. Any suggestion?
Thanks!
Kan
Thanks!
Kan
1 Reply Last Post 17 nov 2010, 12:00 GMT-5
