Lars Gregersen
COMSOL Employee
9 years ago
30 mag 2016, 05:41 GMT-4
You code looks OK.
You should check your model and verify what dataset your results are placed in. Also verify that the model has in fact been solved ;-)
What are the values of x1 and y1? What is the dimension of your geometry?
Please quote any error messages you see. It makes trouble shooting so much easier.
Lars Gregersen
Comsol Denmark
You code looks OK.
Lars Gregersen
Comsol Denmark
9 years ago
30 mag 2016, 10:47 GMT-4
Thanks Lars,
The model has been solved; and the dimension of the study is 2D.
x1, y1 are the coordinates of the point where the pressure is to be extracted from the domain. The error message reads:
Empty Matrix: 0 x 1
I have used the same syntax for a 3D COMSOL demo model (busbar), and the extraction was successful. But in this particular model, I have tried many extraction points and i'm still getting the same error message.
Thanks Lars,
Empty Matrix: 0 x 1
9 years ago
30 mag 2016, 10:55 GMT-4
Empty matrix: 0-by-1
9 years ago
30 mag 2016, 14:15 GMT-4
I have found the cause of the error; as you mentioned earlier, to check the datasets. One of the datasets, which seems to be the default for extraction---dset1, had no solution.
Regards
Femi
Regards
Femi
Lars Gregersen
COMSOL Employee
9 years ago
31 mag 2016, 04:08 GMT-4
I'll see if we can add an error message for this case.
Regards
Femi
Lars Gregersen
Comsol Denmark
[QUOTE]
Regards
Femi
[/QUOTE]
Lars Gregersen
Comsol Denmark
