study strain energy due to external cyclic temperature load
Hello!
I am modeling a three-layered square-shaped sample, which is exposed to external cyclic temperature load. I am interested in the strain energy in the center material. How do I apply temperature load and what physics should be added? Will it be a stationary or time-dependent analysis?
Is there an example for such a case?
Thank you!
Dhan
1 Reply Last Post 24 nov 2010, 08:12 GMT-5
Posted: 1 decade ago 24 nov 2010, 08:12 GMT-5
there are so many examples that I cannot really tell, I know about a thermal stress induced three layer one in the 3.5 doc, so it's most likelely also be in the v4, there they couple thermal stress at different temperatures for a process layered product.
one way is transient, but a series of stationary runs, to get the extreme stress (not the detailed history) can also do
in V4 I would say ST and HT should be enough.
Then the question remains: how do you define your fatigue curves from the cyclic extreme load cases ? There COMSOL does not really have the answer, it's too model dependent
Hi there are so many examples that I cannot really tell, I know about a thermal stress induced three layer one in the 3.5 doc, so it's most likelely also be in the v4, there they couple thermal stress at different temperatures for a process layered product. one way is transient, but a series of stationary runs, to get the extreme stress (not the detailed history) can also do in V4 I would say ST and HT should be enough. Then the question remains: how do you define your fatigue curves from the cyclic extreme load cases ? There COMSOL does not really have the answer, it's too model dependent -- Good luck Ivar
