Initial Values for Laminar Flow
Posted 26 nov 2010, 08:30 GMT-5 2 Replies
I'm having issues with setting inital values. I have a box with a helium inflow on top, and outflow at bottom. Inside there's a small cell. It all works fine, when I set-up these values to proper domains/boundaries:
LF/Fluid prop.
Pressure 1[atm]
LF/Initial Values
Velocity field (0,0,0)
Pressure 1[atm]
LF/Inlet (Laminar Inflow)
Av. Velocity - 1m/s
Lentr - 1m
LF/Outlet
Pressure, no visc. stress - 1[atm],
I plot 3D Arrow volume showing velocity field with flow deformations around the cell. Here's the thing. The target velocity is 30m/s. After I change it to this value, the simulation crashes with information, that consistent inital values cannot be found. I've been changing pressures, entrance length, inital velocity field etc, but I cant find any boundary conditions, that would let me see the results.
Thank You in advance for any tips and hints.
Cheers
LF/Fluid prop.
Pressure 1[atm]
LF/Initial Values
Pressure 1[atm]
Av. Velocity - 1m/s
Lentr - 1m
LF/Outlet
Cheers
2 Replies Last Post 26 nov 2010, 09:02 GMT-5
