No extended mesh generated - error.
I recently posted a question about solving two coupled PDEs. One is an eigenvalue equation and the second is Poissons equation. I might have solved this problem, but the process encounters an error that is not covered by the documentation.
The error I get is in the second step where Poissons equation is solved.
No extended mesh generated.
- Mesh case: -1
- Feature: Stationary Solver 1 (sol1/s1)
I have tried to google the error but without luck. I guess it has to do with the fact that the second study steps lacks a meshing of the geometry or something. Does anyone have an idea what it means.
My script is attached below.
3 Replies Last Post 16 giu 2016, 09:44 GMT-4
Posted: 9 years ago 15 giu 2016, 12:02 GMT-4
Hello William,
I do not work in your field or understand what you are trying to achieve with this model, but one thing I noticed in your file is that you are using u in the right-hand side of the Poisson equation in domains 1 through 3 - but as far as I can tell u is not defined in domain 3 since your Coefficient Form PDE is only posed on domains 1 and 2. At least that is a problem.
I hope this helps.
Hello William, I do not work in your field or understand what you are trying to achieve with this model, but one thing I noticed in your file is that you are using u in the right-hand side of the Poisson equation in domains 1 through 3 - but as far as I can tell u is not defined in domain 3 since your Coefficient Form PDE is only posed on domains 1 and 2. At least that is a problem. I hope this helps. Best, Jeff
Posted: 9 years ago 15 giu 2016, 18:28 GMT-4
Thank you for the answer.
I have now remove the outer domain, such that both equations are only defined on the two inner circles. However, it seems that the error remains. Do you have any idea what this extended mesh error could mean?
Thank you for the answer. I have now remove the outer domain, such that both equations are only defined on the two inner circles. However, it seems that the error remains. Do you have any idea what this extended mesh error could mean?
Posted: 9 years ago 16 giu 2016, 09:44 GMT-4
After a substantial modification to you model like removing a domain and as a result changing some boundary conditions, you may want to build the solver sequence again from scratch.
If the problem persists, as always I would recommend that you consider posting the latest version of your file for Forum users more knowledgeable than me in your field to be able to provide productive feedback.
After a substantial modification to you model like removing a domain and as a result changing some boundary conditions, you may want to build the solver sequence again from scratch. If the problem persists, as always I would recommend that you consider posting the latest version of your file for Forum users more knowledgeable than me in your field to be able to provide productive feedback. Best, Jeff
