Create a PCB layer
Hi!
I want to creat a PCB layer in COMSOL Multyphysics. The PCB layer contains copper and FR4 overlaping each other 4 times. The layers are about 100 micro-meter thick. How should I build this geometry in the best way? Should a make thin cylinders on top of each other or is there any other tool I can use?
Best regards
Maria
1 Reply Last Post 16 giu 2016, 10:25 GMT-4
Niklas Rom COMSOL Employee
Posted: 9 years ago 16 giu 2016, 10:25 GMT-4
Hi Maria,
in PCB design, one option is to use dedicated software for the geometrical design. COMSOL can import the design with the ECAD Import Module. You can choose which layer should have a thickness represented in geometry, and which should be simulated as thin layers. It depends on what happens in each part. Often FR4 is insulating and a little thicker and can thus be represented with a geometrical thickness, while copper is much thinner and is simulated as a thin layer, not having the thickness represented in the geometry. Of course you can draw the geometry in COMSOL yourself if you want.
kind regards
Niklas
Hi!
Best regards
Maria
Hi Maria, in PCB design, one option is to use dedicated software for the geometrical design. COMSOL can import the design with the ECAD Import Module. You can choose which layer should have a thickness represented in geometry, and which should be simulated as thin layers. It depends on what happens in each part. Often FR4 is insulating and a little thicker and can thus be represented with a geometrical thickness, while copper is much thinner and is simulated as a thin layer, not having the thickness represented in the geometry. Of course you can draw the geometry in COMSOL yourself if you want. kind regards Niklas [QUOTE] Hi! I want to creat a PCB layer in COMSOL Multyphysics. The PCB layer contains copper and FR4 overlaping each other 4 times. The layers are about 100 micro-meter thick. How should I build this geometry in the best way? Should a make thin cylinders on top of each other or is there any other tool I can use? Best regards Maria [/QUOTE]
