Compact history error
I received an error when I tried to compact my Comsol file
Syntax error in expression
- Expression: SpaceCharge(root.x[[um]],root.y[[um]])
- Subexpression: [[um]],root
- Position: 19
I cannot understand where the error is coming from. SpaceCharge is an interpolation function.
3 Replies Last Post 23 giu 2016, 10:45 GMT-4
Posted: 9 years ago 23 giu 2016, 05:25 GMT-4
Hi John
Please send your model to support where someone will have a look.
- Position: 19
Lars Gregersen
Comsol Denmark
Hi John Please send your model to support where someone will have a look. [QUOTE] I received an error when I tried to compact my Comsol file Syntax error in expression - Expression: SpaceCharge(root.x[[um]],root.y[[um]]) - Subexpression: [[um]],root - Position: 19 I cannot understand where the error is coming from. SpaceCharge is an interpolation function. [/QUOTE] -- Lars Gregersen Comsol Denmark
Posted: 9 years ago 23 giu 2016, 09:54 GMT-4
I have attached the model.
Daniel Smith COMSOL Employee
Posted: 9 years ago 23 giu 2016, 10:45 GMT-4
Hi John, the problem seems to be with the disabled "2DPlot Group 1" feature under Results. In the "Surface 1" plot, the expression is set to SpaceCharge(root.x[[um]],root.y[[um]]). COMSOL can't interpret the double square brackets when compacting history. To fix the problem, simply replace the expression with SpaceCharge(root.x[um],root.y[um]). You should be able to compact history after making this change.
Dan
Hi John, the problem seems to be with the disabled "2DPlot Group 1" feature under Results. In the "Surface 1" plot, the expression is set to SpaceCharge(root.x[[um]],root.y[[um]]). COMSOL can't interpret the double square brackets when compacting history. To fix the problem, simply replace the expression with SpaceCharge(root.x[um],root.y[um]). You should be able to compact history after making this change. Dan
