No Matlab Livelink response after loading model to Matlab
Posted 23 giu 2016, 14:49 GMT-4 Interfacing, Results & Visualization Version 4.3a, Version 5.1 8 Replies
I have a large Comsol 4.3a model with size almost 50 GB. I would like to run it through MatLab to export all solution data from parametric sweep simulation with almost 1,300 parameter combinations. The problem is that MatLab cannot step to the next script even though its status is busy after finishing loading the model using the following script.
addpath '/cluster/cloud/comsol-43a/mli'
import com.comsol.model.*
import com.comsol.model.util.*
mphstart
ModelUtil.showProgress(true);
model=mphload();
I'm guessing that the model size is too large and there is some limitation on Java about size in the settings. Does anyone know how to solve this problem?
Mengxue
Please keep in mind that COMSOL supports the following versions of MATLAB when interfacing with COMSOL Multiphysics version 4.3:
COMSOL® Version Supported MATLAB® versions
COMSOL 4.3b R2012b + R2013a
COMSOL 4.3a R2012a + R2012b
COMSOL 4.3 R2011b + R2012a
COMSOL 4.2a R2011a + R2011b
COMSOL 4.2 R2010b + R2011a
I hope this helps,
David Hovsepian
Thanks for the quick reply. I'm now using R2015a, but the script works well for my another parametric sweep simulation with 170 parameter combinations. I guess it should be fine to use R2015a. The problem occurs when the number comes to 1,300. That's why I'm guessing the size matters.
Mengxue
Your Matlab version, although officially unsupported for your version of Comsol, is most likely not the problem.
For large models your Matlab and Comsol must run as 64-bit processes.
Older versions of Comsol had a few minor problems with memory management that you may have run into. Upgrading to a newer version of Comsol may solve the problem. You are always welcome to send your model to support where someone can have a look at it in order to see if the problem is fixed in the latest version of Comsol. Since the model is large please remove the solution before sending the file.
Lars Gregersen
Comsol Denmark
Thanks for your reply. I will try the newer version of comsol to see whether this solves the problem.
Actually, I have initiated a case to the support, but they need the license information to fulfill the request, which I cannot provide since the comsol I used is administered by our Engineering School, not by myself.
Mengxue
Hi Lars,
Mengxue
Hi Mengxue
I'm sure your administration can supply you with the necessary information you need to obtain proper support. Comsol does give support to academic customers!
Lars Gregersen
Comsol Denmark
Thanks for your suggestion. I got a reply from the support team after fulfilling the license information, but they cannot give me any support since my version is 4.3a, not 5.2 or 5.2a.
Anyway, my problem is solved following your previous suggestion to use newer version of comsol. I'm now using comsol 5.1 (the latest one installed in our school's cluster). It should be some memory issue of the old version.
Thanks for your help!
Mengxue
I'm glad to hear that you now found a way to get official support. If your university is paying such that you can get support you might as well use it.
On the same note. If your university is paying for support it is also paying for the latest release of Comsol. Hence you might as well use it. All versions of Comsol brings significant new features and performance improvements that all users of Comsol can benefit from. The newly released version 5.2a includes lots of new features compared to 5.2 (even though the name change doesn't reveal it).
I know that many universities only install new releases of programs during the summer break. This will be a good opportunity to kindly ask the IT-department to install the new release! Also it is good to know that you can install new releases of Comsol without deleting any old versions.
Here is a list of the new features in Comsol 5.2a:
www.comsol.com/release/5.2a
Oh yes, one final note: if your problem with your model still exists with version 5.1 then send the model to support. If the file is very large then you can delete its solution to save space before sending the model.
Lars Gregersen
Comsol Denmark
Thanks for the detailed explanation. The IT staff in our school will install new version next week.
Mengxue
Suggested Content
- FORUM How to continue the study after stopped using livelink for matlab?
- BLOG How to Manually Work with Entity Numbers in Selections
- FORUM Saving simulated model as mat file in matlab, livelink
- KNOWLEDGE BASE Error: Failure Loading MATLAB Libraries. This model requires that MATLAB is available.
- FORUM Livelink for MATLAB taking too much time to simulate
