Restricting a plot to a domain or boundary without a separata data set?
Posted 30 giu 2016, 10:24 CEST Geometry, Results & Visualization Version 5.2a 2 Replies
I have a parametric solution set. I have created a 2D plot group, where each sub-plot of this group is using the parent plot group's data set. This allows me to switch all plots to different parameter values with one click.
Now, I would like to add another plot to this group, which is restricted only to a boundary. As far as I know I can do this by creating a data set, and adding a selection to it, and then use this data set in that particular plot. The problem with this approach is that this plot is NOT using its parent group's dataset, but its own data set, and I need to change parameter values at two different nodes. This is a guarantee for messing it up at some point, and show an inconsistent plot, some parts of it showing the results belonging to one parameter, and some other parts of it showing the results of another parameter.
Can this be done in a more consistent way?
Thank you
Daniel
Thank you
Daniel
2 Replies Last Post 30 giu 2016, 14:45 CEST
