building environment fluid flow help
Posted 6 dic 2010, 14:52 GMT-5 Fluid & Heat Version 4.0a 1 Reply
I am attempting to simulate the air flow in a cross section of an agricultural building. Air flow is driven by a static pressure difference between the inside and the outside of the building of 25pa.
2D problems are representations of infinite 3rd dimension extent by default. However, i wish to add mean flux in the third dimension which maintains the static pressure of the domain. The domain has a constant pressure inlet and the outlet needs to be through the domain's plane.
Is this something that would be implemented by modifying the fluid properties' equations? Or am i missing a way to do this the easy way? Thus far i have learned only how to manipulate the default settings in the model tree.
I have attached the nonworking symmetry case model for illustration purposes.
Im new at comsol so feel free to tell me that im doing something stupid...
1 Reply Last Post 8 dic 2010, 16:21 GMT-5
