7 dic 2010, 08:36 GMT-5
first of all get the latest update on the COMSOL web site as there is still a typo in one of the formulas fo "mef" in 4.1.0.88, and check again
see
www.comsol.eu/support/updates/comsol41p/
see http://www.comsol.eu/support/updates/comsol41p/
Magnus Olsson
COMSOL Employee
7 dic 2010, 11:23 GMT-5
We have indeed introduced limitations in how magnetic and electric boundary features can be combined. The reason is that certain combinations are unphysical and will result in ill-posed models that will be numerically unstable or give rise to unphysical solutions.
The Magnetic and Electric Fields interface is based on Maxwell-Ampère's law, in which the equation of continuity is inherent. Thus, any model must provide closed current loops. The current path can close as volume currents, surface currents, edge currents and combinations thereof.
Now, constraining the electric potential is normally associated with a current source or sink and is thus only allowed on a boundary supporting induced surface currents (magnetic insulation or impedance boundary condition). Magnetic insulation is by the way allowed on interior boundaries if you add it as a new feature. The default magnetic insulation feature is limited to external boundaries only.
Magnus Olsson
COMSOL
Magnus Olsson
COMSOL
7 dic 2010, 15:15 GMT-5
indeed it takes some time to convince oneself of the true effects of magnetic insulation/electric shielding BC's and the effective current loops.
That is also why following your ACDC course is very interesting.
Everything cannot be explained in the doc, I do partially agree, some features are of rather "natural physics knowledge" but are still not obvious before one have the occasion to play with physics as we can now with COMSOL
9 dic 2010, 02:27 GMT-5
Okay, thanks for the input, guys :)
With Magnus' hint I was able to model my problem the way I wanted to model it.
The old word popped into my mind: "It's not a bug - it's a feature!" ;)
Bye
MV
Bye
MV
9 dic 2010, 04:19 GMT-5
I am using COMSOL 3.5a and want to solve a multi-phsics problem. One of the phenomenon I use is the the Meridional Induction and Electric Currents, Potentials. In the subdomain setting there are two vectoral diffrenetial equation. As far as I understand from What Magnus says, there is no need to define the current continuity equation. It is inherent in the vectoral differential equations. Am I right?
9 dic 2010, 07:14 GMT-5
I believe what Magnus refers to is that you need a closed path for your current in ACDC, typically if you i.e. simulate a 1/4 of a coil system you must ensure that the current can flow back via the appropriate BC's. This implies that not all BC's are compatible with this current flow
As well that in 3.5 this was not strictly imposed, which lead to illconditionned models with convergence issues, or not correct results. Getting a nice rainbow color view is easy, knowing for sure its correctly representing "reality" is another story (but the latter is the one you as engineer must stand up for)
