10 dic 2010, 01:27 GMT-5
most probably because "rho" is defined alread inside COMSOl for the material density. Read the errorlist from bottom to top, he first error was "rho". But I might be wrong, it's just my first guess ;)
COMSOL does not always flag when you use and redefine an internal variable, bacause its "allowed" and required if you are tweaking the equations, you are supposed to be the "master" and to know ... it's just that there are som many things to "know" when you mix up all these physics so nicely ...
Magnus Ringh
COMSOL Employee
10 dic 2010, 02:54 GMT-5
The problem here is that global equations and variables cannot depend on space coordinates such as x and y.
It seems that you define u = rho, where rho is a function of x and y. You can define rho using a domain variable (in version 4) or a subdomain expression variable (in version 3.5) without any equation. If you want u as a dependent variable, you can solve u = rho as a very simple PDE in the domain.
Magnus Ringh, COMSOL
10 dic 2010, 03:32 GMT-5
should also have taught about that one, you have told me that before Magnus ;)
12 dic 2010, 08:37 GMT-5
Hi, Magnus
Thank you for your reply.
Indeed, I should solve the nonlinear equations like
r=f(rp,thetap,theta)
theta=g(rp,thetap)
where r=sqrt(x^2+y^2) and theta=angle(x+i*y) are the polar coordinates in certain domain, respectively. f and g are known nonlinear functions. The equations is actually a transformation from (rp,thetap) to (r,theta). And the problem is that for give postion (x,y) (or (r,theta)) in certain domain, (rp,thetap) should be calculated and then the Jacobian
?r/?rp ?r/?thetap
?theta/?rp ?theta/?thetap
or
|?x/?xp ?x/?yp|
|?y/?xp ?y/?yp|
where xp=rp*cos(thetap) and yp=rp*sin(thetap), respectively.
rediaof eda
Hi, Magnus
theta=g(rp,thetap)
?r/?rp ?r/?thetap
or
|?x/?xp ?x/?yp|
|?y/?xp ?y/?yp|
rediaof eda
21 nov 2013, 06:30 GMT-5
Dear Magnus
I have the same problem " Failed to evaluate variable Jacobian, Global scope " But I dont habe actually any global variables...
I had a simulation with AC/DC which simulates Three-phase electric power and it wokrd.
I modified the simlation so that i inserted an electrical circuit which replaces the 3 voltage sources for the 3 phase and after this it dosent work anymore.. I cant find a reason for it
Dear Magnus
