Change name of independent variable
I am solving general PDE in coordinates (x - position, v - velocity). Is there possibility to set name of independent variables to (x,v). By default are independent variables (x,y).
Thanks for advice
Jakub
2 Replies Last Post 15 giu 2016, 06:45 GMT-4
Hello Jakub Zlamal
Posted: 8 years ago 15 giu 2016, 05:43 GMT-4
This is my problem too! I'm going to solve a Wave like equation which (u,t) should be (u,y). c=0 and ea is a function of (u,y)
Can COMSOL solve this equation?
Regards
This is my problem too! I'm going to solve a Wave like equation which (u,t) should be (u,y). c=0 and ea is a function of (u,y) Can COMSOL solve this equation? Regards
Magnus Ringh COMSOL Employee
Posted: 8 years ago 15 giu 2016, 06:45 GMT-4
Yes, you can change the names of the spatial coordinates (independent variables) under Spatial coordinates in the General section of the Settings window for the Component node in the model tree. The name of the independent variable for time is t and cannot be changed.
Magnus Ringh, COMSOL
Hi, Yes, you can change the names of the spatial coordinates (independent variables) under Spatial coordinates in the General section of the Settings window for the Component node in the model tree. The name of the independent variable for time is t and cannot be changed. Best regards, Magnus Ringh, COMSOL
