S-Parameters in Microwave Cavity
Is it normal having a -30dB magnitude of S11 in a certain frequency, even if the the Microwave Cavity (Aluminum) is empty? What does it mean exactly? It could be the some parts of the cavity absorbs the MWs.
4 Replies Last Post 29 ago 2016, 13:58 GMT-4
Posted: 8 years ago 26 ago 2016, 10:49 GMT-4
Did you apply PEC or impedance boundary condition on cavity wall? Perform surface integration of power density at cavity wall to determine power absorption by wall.
Posted: 8 years ago 26 ago 2016, 11:54 GMT-4
Dear Sohan, Thanks for your attention, first I have assigned the cavity walls PEC then I have changed them into Impedance boundaries, because I also added the heat transfer in solids and convective heat flux for the outer surface of the cavity. More or less I followed the example of RF Heating.
Posted: 8 years ago 29 ago 2016, 11:40 GMT-4
Integrate the power absorbed in wall and load. Then determine the absolute value of S11 parameters any point on surface of the domain. Inpt_power*(1-abs(S11)^2) should be equal to integrated power. If this numbers are different than check for mesh quality. Let the software select the meshing scheme.
Posted: 8 years ago 29 ago 2016, 13:58 GMT-4
I suppose that I have to do these integrations at one fixed frequency, right?
