View global data in Matlab
Dear all,
I calculated the magnetic force between two magnets. I can get the force through postprocessing->data display->global and write name_forcex_emqa under the expression. The force is then displayed in the dialog.
I have now saved the .m file and run the simulation in matlab.
How can I get the resulting magnetic force? Which command should I use?
I need this because I would change the geometry and run various simulation and automatically display force.
Thank you
Blaz
4 Replies Last Post 21 dic 2010, 01:21 GMT-5
Posted: 1 decade ago 20 dic 2010, 07:10 GMT-5
Hi Blaz,
if you are working with COMSOL 3.5, I think you are looking for this command:
data = postglobaleval(fem, 'name_forcex_emqa')
Find your results in the structure under data.y
Stefan
Hi Blaz, if you are working with COMSOL 3.5, I think you are looking for this command: data = postglobaleval(fem, 'name_forcex_emqa') Find your results in the structure under data.y Good luck Stefan
Posted: 1 decade ago 20 dic 2010, 07:39 GMT-5
I tried that and I get:
>> data = postglobaleval(fem, 'mag1_forcex_emqa')
??? Error using ==> postglobaleval at 70
Expression must be a cell array.
Thank you very much for your support
Blaz
I tried that and I get: >> data = postglobaleval(fem, 'mag1_forcex_emqa') ??? Error using ==> postglobaleval at 70 Expression must be a cell array. Thank you very much for your support Blaz
Posted: 1 decade ago 20 dic 2010, 08:43 GMT-5
There was a little mistake. You have to write the variables as a cell array. Now we have:
data = postglobaleval(fem, {'mag1_forcex_emqa'})
Stefan
There was a little mistake. You have to write the variables as a cell array. Now we have: data = postglobaleval(fem, {'mag1_forcex_emqa'}) Good luck Stefan
Posted: 1 decade ago 21 dic 2010, 01:21 GMT-5
Thank you very much. It works :)
