air cylinder
I modeled a rotating air cylinder that is divided in 4 quarters. I am trying to find out pressure distribution across the cylinder. My idea is the pressure would be accommodate at the outer walls of the cylinder due to the centrifugal force and also with the wall of quarter that would push the air along with it.
For more viscous fluids it behaves as I thought but for air's dynamic viscosity. It is totally opposite.
The model is attached. If any one can give suggestion? as I neither know about fluid dynamics nor much about Comsol
1 Reply Last Post 10 ott 2016, 06:55 GMT-4
Hello bluesmoke
Posted: 9 years ago 10 ott 2016, 06:55 GMT-4
Hi bluesmoke,
I'm facing the same problem. Have you found the solution? Thanks!
Wenbo liu
Hi bluesmoke, I'm facing the same problem. Have you found the solution? Thanks! Best, Wenbo liu
