Cantilever beam with distributed load modeling
I want to simulate a cantilever beam fixed from one side and having a distributed load on one of its faces. I made a lot of changes and i simplified it very much, however i still receiving that error.
Error: 7248
Undefined value found
Exception:
com.femlab.jni.FlNativeException: Undefined value found Solvermodel
Stack trace:
at solvermodel.cpp, row 1808, (Undefined value found in the equation residual vector.
There are 352828 degrees of freedom giving NaN/Inf in the vector for the variable u
at coordinates: (1.24935e-005,9.51916e-005,0.00025), (9.99349e-006,9.76916e-005,0.00025), (1.06185e-005,9.36283e-005,0.00025), (9.98698e-006,9.53832e-005,0.00025), (7.48047e-006,9.55748e-005,0.00025), ...
There are 352828 degrees of freedom giving NaN/Inf in the vector for the variable v
There are 352828 degrees of freedom giving NaN/Inf in the vector for the variable w
at com.femlab.solver.FlSolver.femStatic(Native Method)
at com.femlab.solver.FemStatic.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.ae.run(Unknown Source)
Please help me !
3 Replies Last Post 23 dic 2010, 09:24 GMT-5
Posted: 1 decade ago 23 dic 2010, 03:04 GMT-5
this means, from my understanding, that your model is not fully defined, typically too few BC to have an unique solution
Hi this means, from my understanding, that your model is not fully defined, typically too few BC to have an unique solution -- Good luck Ivar
Posted: 1 decade ago 23 dic 2010, 07:59 GMT-5
I have defined one of the faces to be fixed, and all the remaining 5 faces to be free and one of them has a load on it.
what else i have to define.
I am appreciating your help.
I have defined one of the faces to be fixed, and all the remaining 5 faces to be free and one of them has a load on it. what else i have to define. I am appreciating your help.
Posted: 1 decade ago 23 dic 2010, 09:24 GMT-5
then check your material data if there is not a red flag therein, or if you do not have a domai or BC definition but wotout having selected correctly the items
Hi then check your material data if there is not a red flag therein, or if you do not have a domai or BC definition but wotout having selected correctly the items -- Good luck Ivar
