Pressure Velocity Couplings
While doing fluid flow modeling (CFD), in softwares like FLUENT which are based on the finite-volume method, we define Pressure-Velocity Couplings like SIMPLE, or PISO etc.
I do not find any information on this in COMSOL though. Can somebody help me out on this ?
Harish
2 Replies Last Post 4 gen 2011, 20:05 GMT-5
Posted: 1 decade ago 29 dic 2010, 02:20 GMT-5
I do not know "fluent" but I'm not sure COMSOl is treating the equations in the same way.
Check the equations in COMSOL for the different physics and modes, and you will see how it's done.
If I remember well "finite volume" it's related to "rho" the density and how invariant you consider it, no ?
Hi I do not know "fluent" but I'm not sure COMSOl is treating the equations in the same way. Check the equations in COMSOL for the different physics and modes, and you will see how it's done. If I remember well "finite volume" it's related to "rho" the density and how invariant you consider it, no ? -- Good luck Ivar
Posted: 1 decade ago 4 gen 2011, 20:05 GMT-5
It is likely using a projection strategy very similar to the SIMPLE scheme. Solve the momentum equations with or without pressure (either implicit or explicit) to obtain a predicted velocity. Solve a pressure poisson equation to obtain a pressure correction that can be used to update velocity so that continuity is satisfied. What I would love to know is if they are solving pressure poisson, what, if any boundary conditions are used for this equation.
If you are using v3.5 you will probably see that COMSOL gives several options regarding choice of element. All of these options are now gone in v4.1 in favour of what is likely a stabilised P1P1 element (linear velocity and pressure approximation). Additional stabilisation for the convective terms looks like it is achieved by a streamline upwinding.
Here are a few references that could be a useful starting point if you are looking for more info on solving Incompressible Navier-Stokes with FEM.
(Brooks, Hughes 1982, related to upwinding) Streamline upwind/Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations
(Langtangen et. al, 2002, related to NS solution strategies) Numerical Methods for Incompressible Flow
Anything by a guy called Tezduyar, which will probably relate to implementing upwinding strategies.
Anything about equal order elements/circumventing the LBB condition which will talk about additional stabilisation for elements that do not satisfy the LBB condition.
It is likely using a projection strategy very similar to the SIMPLE scheme. Solve the momentum equations with or without pressure (either implicit or explicit) to obtain a predicted velocity. Solve a pressure poisson equation to obtain a pressure correction that can be used to update velocity so that continuity is satisfied. What I would love to know is if they are solving pressure poisson, what, if any boundary conditions are used for this equation. If you are using v3.5 you will probably see that COMSOL gives several options regarding choice of element. All of these options are now gone in v4.1 in favour of what is likely a stabilised P1P1 element (linear velocity and pressure approximation). Additional stabilisation for the convective terms looks like it is achieved by a streamline upwinding. Here are a few references that could be a useful starting point if you are looking for more info on solving Incompressible Navier-Stokes with FEM. (Brooks, Hughes 1982, related to upwinding) Streamline upwind/Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations (Langtangen et. al, 2002, related to NS solution strategies) Numerical Methods for Incompressible Flow Anything by a guy called Tezduyar, which will probably relate to implementing upwinding strategies. Anything about equal order elements/circumventing the LBB condition which will talk about additional stabilisation for elements that do not satisfy the LBB condition.
