error message in RF module
I am gettting an error message when i simulated a model in RF module. I cant understand this error.
May be some of you would have encountered this error message. The error is
Error: 9160
Unknown or unsupported property.
- Property: maxsegiter segterm
So can anybody can help me with this?
Regards
Rajiv
1 Reply Last Post 7 lug 2009, 04:05 GMT-4
Posted: 2 decades ago 7 lug 2009, 04:05 GMT-4
Error: 9160
Regards
Rajiv
It could be that you have updated with the 32-bit hotfix, but you are running 64-bit COMSOL. This can be verified by running COMSOL in 32-bit mode (on Windows, comsol.exe instead of comsol64.exe, on Linux,
run "comsol -32"), in which case the problem should not occur.
If this is the problem, fix it by downloading the 64-bit hotfix jar-file from
www.comsol.com/support/updates
Make sure you remove the old hotfix file before you start, and then and install the 64-bit hotfix according to the instructions on the download page.
Niklas Rom, COMSOL
[QUOTE] Hi I am gettting an error message when i simulated a model in RF module. I cant understand this error. May be some of you would have encountered this error message. The error is Error: 9160 Unknown or unsupported property. - Property: maxsegiter segterm So can anybody can help me with this? Regards Rajiv [/QUOTE] It could be that you have updated with the 32-bit hotfix, but you are running 64-bit COMSOL. This can be verified by running COMSOL in 32-bit mode (on Windows, comsol.exe instead of comsol64.exe, on Linux, run "comsol -32"), in which case the problem should not occur. If this is the problem, fix it by downloading the 64-bit hotfix jar-file from http://www.comsol.com/support/updates Make sure you remove the old hotfix file before you start, and then and install the 64-bit hotfix according to the instructions on the download page. Niklas Rom, COMSOL
