Electric field - ASCII
Hi all,
I used COMSOL 3.5a to find the electric field induced near a volumic charge distribution. The field is noted E(x,y,z).
Now, I would like exported the ASCII-text file associated to this electric filed only to post-process my data with matlab.
What is the best way to make this ASCII-file ? I would like that this file be in the form of four columns (X, Y, Z, E)...
Thank you for your help
Craig Dellin
BELL-San Francisco City
4 Replies Last Post 1 gen 2011, 04:56 GMT-5
Posted: 1 decade ago 31 dic 2010, 12:13 GMT-5
Have you an idea to my previous post ?
Craig
Have you an idea to my previous post ? Craig
Posted: 1 decade ago 31 dic 2010, 12:20 GMT-5
Why a txt file, from matlab you can use the posteval() or postinter() (v3.5a) to extract the data directly, no
Check the doc
Hi Why a txt file, from matlab you can use the posteval() or postinter() (v3.5a) to extract the data directly, no Check the doc -- Good luck Ivar
Posted: 1 decade ago 31 dic 2010, 12:39 GMT-5
Thank you for your answer,
Ok Ivar but 'posteval' allowed me only to extract the differents values of my field (just an electrostatic potential at differents points in my domain)...More I would like extract the spatial-coordinates where the values of this field are calculated.
Best
Craig
Thank you for your answer, Ok Ivar but 'posteval' allowed me only to extract the differents values of my field (just an electrostatic potential at differents points in my domain)...More I would like extract the spatial-coordinates where the values of this field are calculated. Best Craig
Posted: 1 decade ago 1 gen 2011, 04:56 GMT-5
Check the Forum, that question has came up several times (cannot remember the reply ;) check also the KB there are a lot of tricks ther too.
Then you have the postinterp() where you define the grid points and the response is interpolated onto your grid
Hi Check the Forum, that question has came up several times (cannot remember the reply ;) check also the KB there are a lot of tricks ther too. Then you have the postinterp() where you define the grid points and the response is interpolated onto your grid -- Good luck Ivar
