internal error in geometry decomposition
I want to make a simulation about eddy current testing for flaw in a tube. In my model a quarter of tube is built and I made a flaw in the middle of the tube. I got a error as the title when I try to mesh the geometry. why is there such a error. I'm confused.
Attached is my model. Thank you very much!
2 Replies Last Post 5 gen 2011, 04:28 GMT-5
Posted: 1 decade ago 4 gen 2011, 05:40 GMT-5
I cannot open your model in 4.1, there is an internal error in the geoemtrical decomposition, it seems too complex, or some pars are "almost touching", anyhow why all those layers ?
cannt you simply make a 1/4 shell an then add a slot as a few rectangles. Then you change the properties of the material.
Even I beleive you can make a virtual slot by using some bolean expressions in the material properties.
I always suggest to start ()very simple to get the model running and to be sure it's corect, then one can make it more realistic
furthermore I can only strongly suggest to get hands on the latest v4.1 patched as it works far more smoother than the 4.0
THere are more on this here www.comsol.eu/support/knowledgebase/1089/
Hi I cannot open your model in 4.1, there is an internal error in the geoemtrical decomposition, it seems too complex, or some pars are "almost touching", anyhow why all those layers ? cannt you simply make a 1/4 shell an then add a slot as a few rectangles. Then you change the properties of the material. Even I beleive you can make a virtual slot by using some bolean expressions in the material properties. I always suggest to start ()very simple to get the model running and to be sure it's corect, then one can make it more realistic furthermore I can only strongly suggest to get hands on the latest v4.1 patched as it works far more smoother than the 4.0 THere are more on this here http://www.comsol.eu/support/knowledgebase/1089/ -- Good luck Ivar
Posted: 1 decade ago 5 gen 2011, 04:28 GMT-5
Ivar, thank you for your reply. I use another method (extrude) to build the geometrical model and there is no error now. I do not know why. It is very weird. The final geometrical models are same. Fortunately the model is built yet.
Our software will be updated in a few days. Thank you for your suggestion.
Best regards.
Hi, Ivar, thank you for your reply. I use another method (extrude) to build the geometrical model and there is no error now. I do not know why. It is very weird. The final geometrical models are same. Fortunately the model is built yet. Our software will be updated in a few days. Thank you for your suggestion. Best regards.
