Modeling of a magnet
Posted 14 gen 2011, 12:16 GMT-5 4 Replies
Hi all,
I want to model a cylindrical static magnet in Comsol 4.0a. From the manufacturer I obtained the following properties:
- magnetic flux density inside the magnet
- magnetic flux density on the surface of the magnet
- demagnetization (BH) curve (magnetic flux densitiy over external magnetic field)
My questions now is how to incorporate these properties into a model to run a realistic field simulation. A first attempt using the BH-curve property under 'Magnetic Flux Conservation' in combination resulted in a binary field distribution when putting the magnet in air surrounding (B max. inside the magnet, B zero in the air medium). Since this is obviously not the correct solution, hopefully you can give me a better approach to solve my problem.
Thanks in advance for helping me out.
Matthias
Matthias
4 Replies Last Post 17 gen 2011, 13:05 GMT-5
