How to change coodinate system in COMSOL 4.1?
I am using 1D geometry and want to change the axis from "x" to "r" .
5 Replies Last Post 18 gen 2011, 06:03 GMT-5
Posted: 1 decade ago 17 gen 2011, 07:35 GMT-5
the best is to do that when you generate your model (and not later) because then there might be things leftover. When you set-up the physics, you have the screen with the dependent variables, you update change the name here , before going to the selection of the solver
Hi, the best is to do that when you generate your model (and not later) because then there might be things leftover. When you set-up the physics, you have the screen with the dependent variables, you update change the name here , before going to the selection of the solver -- Good luck Ivar
Posted: 1 decade ago 17 gen 2011, 07:41 GMT-5
This is how I change the dependent variables (u), I'm looking to change the independent variables (x)
This is how I change the dependent variables (u), I'm looking to change the independent variables (x) Thanks
Posted: 1 decade ago 17 gen 2011, 08:03 GMT-5
you are right, then I have a doubt where it is in v4, maybe its not possible ? I do believe I did it in 3.5a though.
Just now I do not have access to my COMSOL ;)
if you want "r" it's for 1D axi, but then your equations are also tuned for 1D-axi I do believe
Hi you are right, then I have a doubt where it is in v4, maybe its not possible ? I do believe I did it in 3.5a though. Just now I do not have access to my COMSOL ;) if you want "r" it's for 1D axi, but then your equations are also tuned for 1D-axi I do believe -- Good luck Ivar -- Good luck Ivar
Posted: 1 decade ago 18 gen 2011, 02:21 GMT-5
I think this is possible, since when I import working v3.5 file to v4.1 with 'r' instead of 'x' it's working. Looking at the m.file (import file from v3.5 to v4.1 =>save as m.file=> open m.file) brings me nowhere since, I think, the change between "x,y,z" coordinate to "r,y,z" is hidden in mphbin file.
Posted: 1 decade ago 18 gen 2011, 06:03 GMT-5
probably is, then ask support, I cannot tell. Anyhow I tend to stick to the default as much as possible, there are so many formulas therein, that it's often easier to adopt COMSOL's ways than rather try to adapt to some article o your own way
Hi probably is, then ask support, I cannot tell. Anyhow I tend to stick to the default as much as possible, there are so many formulas therein, that it's often easier to adopt COMSOL's ways than rather try to adapt to some article o your own way -- Good luck Ivar
