Problem with electric potential between 2 electrodes
Posted 23 nov 2016, 11:25 GMT-5 3 Replies
I am trying to do simple 2d electrostatic simulation of electric field strength between two electrodes in air. The distance between electrodes is very high - about 60 metres. I defined one electrode as ground and second electrode as terminal with applied voltage. Around the electrodes I draw big circle representing air with zero charge boundaries.
I am stuck at electric potential calcualation. The problem is - when I apply voltage 1 V on the electrode, I still have electric potential of half the applied voltage in the middle between the electrodes (30m from electrode) and electric potential is also nearly everywehere in the air, which is unacceptable. There should be zero electric potential everywhere in the air few milimetres from the electrode.
Besides, when I apply voltage of 100 kV on the same model, it is still the same situation. There is very high electric potential everywhere in the air and not just around the electrode.
Can anyone tell me, where is the problem ?
3 Replies Last Post 23 nov 2016, 14:52 GMT-5
