Simulate constat flow rate trough a pipe
Posted 9 dic 2016, 09:11 GMT-5 Computational Fluid Dynamics (CFD) Version 5.2a 1 Reply
I would like to simulate a simple situation of laminar flow rate through a pipe. This pipe is a section of a tube which is a part of a closed circuit where a pump imposes a constant flow rate.
I was thinking to simulate this by simply drawing 2D axysimmetric rectangle and imposing at the inlet and outlet a laminar inflow/outflow with the same flow rate value.
However, when I try to do this, the solution does not converge.
Any tips on how to simulate a constant flow rate through a pipe?
Thanks in advance,
Kind Regards,
Simona
Thanks in advance,
Kind Regards,
Simona
1 Reply Last Post 9 dic 2016, 11:00 GMT-5
