8 years ago
14 dic 2016, 09:46 GMT-5
If you get the same results for an extremely fine and a normal mesh
it could mean that a low resolution ( degree of freedoms) is sufficient to
accurately solve the given mathematical problem.
Maybe you could compute solution on even coarser grids, to see if the
mesh covergence deteriates.
Also how do you determine the difference of the results between the
two meshes. Only by optical comparison or do you use some kind of quantiative measurement?
7 years ago
15 mar 2017, 10:04 GMT-4
Hello, thank you for your answer, however i couldn't build the mesh for the whole geometry as i said, for example if i would choose finer mesh the same error message will appear because my layer thickness is much smaller than the minimum element size for the finer mesh. I don't know if you get it.
Furthermore, my geometry dimensions changes when i change a parameter that i defined so that's why for a specific value of this paremeter mesh could work but for other values i get the error message and i couldn't build my mesh
Thank you again
Oh sorry i thought you replied on my last question sorry ! could you check my question about mesh construction please ?
Thank you again
