MATLAB LiveLink
Hey there,
I am using LiveLink MATLAB but when running my model, the notice "Undefined function or variable 'mphopen'" is emerged on the command window. However, I have set up the file "domain_activation_llmatlab" in the MATLAB path. could it be some problem related to LiveLinke? How could I find it that my COMSOL 5.2a can LiveLink to the MATLAM R2016a.
this is one of the comsol's sample problems (www.comsol.com/model/domain-activation-and-deactivation-12060). I, however, cannot do this. what do you suggest. the MATLAB code is as follows:
model = mphopen('domain_activation_llmatlab');
domInd = [2,3,5,4];
ht = model.physics('ht');
for i = 1:8
k = mod(i,4);
if k == 0
k = 4;
end
ht.selection.set([1 domInd(k)]);
ht.feature('init2').selection.set(domInd(k));
model.study('std1').run;
if i==1
cpt1 = model.result.dataset.create('cpt1', 'CutPoint3D');
cpt1.set('pointx', '0 L/2 L');
cpt1.set('pointy', '0 L/2 L');
cpt1.set('pointz', 'L/10');
pg1 = model.result.create('pg1', 'PlotGroup1D');
pg1.set('data', 'cpt1');
ptgr1 = pg1.feature.create('ptgr1', 'PointGraph');
ptgr1.set('legend', 'on');
pg2 = model.result.create('pg2', 'PlotGroup3D');
surf1 = pg2.feature.create('surf1', 'Surface');
surf1.set('rangecoloractive', 'on');
surf1.set('rangecolormax', '336');
surf1.set('rangecolormin', '293.15');
ht.feature('init1').set('T', 1, 'T');
v1 = model.sol('sol1').feature('v1');
v1.set('initsol', 'sol1');
end
figure(1)
mphplot(model,'pg1','rangenum',1)
hold on
figure(2)
subplot(4,2,i)
pg2.setIndex('looplevel','25',0);
mphplot(model,'pg2');
time = mphglobal(model,'t','solnum','end');
model.param.set('t0',time);
disp(sprintf('End of iteration No.%d',i));
end
1 Reply Last Post 12 gen 2017, 09:12 GMT-5
Posted: 9 years ago 12 gen 2017, 09:12 GMT-5
Make sure you start "Matlab with Comsol" before running any scripts in Matlab that use Comsol
See the manual Introduction to LiveLink for Matlab in the chapter called Starting COMSOL with MATLAB.
Lars Gregersen
Comsol Denmark
Hi Make sure you start "Matlab with Comsol" before running any scripts in Matlab that use Comsol See the manual Introduction to LiveLink for Matlab in the chapter called Starting COMSOL with MATLAB. -- Lars Gregersen Comsol Denmark
