Henrik Sönnerlind
COMSOL Employee
7 years ago
13 gen 2017, 05:41 GMT-5
You can either add a Filter node to the plot, or a Selection node to the data set.
Henrik
Henrik
7 years ago
13 gen 2017, 08:03 GMT-5
Thanks very much for reply.
I add Selection node to the Data set. My plot now look very neat and tidy. But I can not add many Selection node. I want to draw electric field out side metal and current inside metal. is it possible?
Henrik Sönnerlind
COMSOL Employee
7 years ago
13 gen 2017, 11:14 GMT-5
Solution 1: Copy the data set and use another selection on the copy. Use two plots with different data set selections in the same plot group.
Solution 2: Do not use the date set selection at all. Instead, use two plot nodes with different Filter subnodes. The syntax for using only say boundary 6 in a surface plot is 'dom==6' in the logical expression.
Henrik
Henrik
7 years ago
14 gen 2017, 06:44 GMT-5
The second solution is very convenient. Thank you very much for your guide.
