Attempt to evaluate nonintegral power of negative number.
Alex Moreno Bellostes
Hi, I am new to comsol when creating a model with a default mesh the model works, but to check the independence of the mesh I want to simulate the model with different sizes of mesh, to introduce a mesh finer I get the following error:
- Function: ^
Failed to evaluate variable.
- Variable: comp1.ht.hf1.fLow
- Defined as: (((0.3387*comp1.ht.hf1.kExtFluid)*(comp1.ht.hf1.Pr^0.33333333333333331))*(comp1.ht.hf1.Re^0.5))/(comp1.ht.hf1.L*((1+((0.046800000000000001/comp1.ht.hf1.Pr)^0.66666666666666663))^0.25))
- Expression: nojac(2*((comp1.ht.hf1.fLow*comp1.ht.hf1.hsExprLow)+(comp1.ht.hf1.fHigh*comp1.ht.hf1.hsExprHigh)))
- Variable: comp1.ht.hf1.h_expr
- Defined as: nojac(2*((comp1.ht.hf1.fLow*comp1.ht.hf1.hsExprLow)+(comp1.ht.hf1.fHigh*comp1.ht.hf1.hsExprHigh)))
- Defined as: comp1.ht.hf1.h_expr
- Variable: comp1.ht.hf1.q0
- Defined as: comp1.ht.hf1.h*(comp1.ht.hf1.Text-comp1.ht.hf1.Tvar)
- Expression: (comp1.ht.hf1.q0*comp1.ht.d)*dvol
Failed to evaluate Jacobian of expression.
- Expression: (comp1.ht.hf1.q0*test(comp1.ht.hf1.Tvar)*comp1.ht.d)*(dvol)
How can I know what the error is?
0 Replies Last Post 20 gen 2017, 05:33 GMT-5
Hello Alex Moreno Bellostes
