27 gen 2011, 03:49 GMT-5
there are many changes in v4, I spent also some time to get used to it.
first of all the "report" feature as per v3.5 is not yet implemented, you can generate plots, and save the generation such that its done in one go also in 4.1, it must be defined once manually (right click on the plot nodes to see all options)
for the formulas, you need to catch the new way, no longer suffix "_smsld" but prefix "solid." for all variables. Then in v4 and Structural, the "Deformed frame" is by default "on" this means that you have a different material and spatial (deformed) frames activ.
In 3.5 the "deformed frame" was off and all frames were referred to as x,y,z (lowercase). In v4 the spatial (deformed) frame is "on" and uses the lowercase x,y,z, while the material frame and the mesh has the uppercase X,Y,Z hence you need to think in which frame you are for your formulas, and often v3.5 lowercase x,y,z (derivatives) become X,Y,Z uppercase.
Its the old story of Euler or Lagrangian reference frame issue (more common to the fluidics)
27 gen 2011, 05:25 GMT-5
Thanks for suggestions. I am not able to write the last expression in comsol v 4.1. I have to do partial differentiation of entropy S w.r.to time t.Can you suggest me expression?
Regards!!
Deepak
Regards!!
Deepak
27 gen 2011, 11:00 GMT-5
if you cannot find any any internal name for the entropy derivative, you might get away with a d(S,t) the differentiator operator d(,) check the doc
27 gen 2011, 13:22 GMT-5
Thanks again Ivar...I got the differential operator by exploring the documentation.partial differential can be written as pd(S,t) for my case.
Regards!!
Deepak
Regards!!
Deepak
28 gen 2011, 01:25 GMT-5
Yes correct, I had forgotten to add "pd(,)" to the list of potential operator, if it not d(,) its pd(,) ;)
