problem with general extrusion
I need to model high Reynolds flow in 3D. The model is very simple: it consists of one cylinder of length 40 meters, broken into pieces of 5 meters. I would like passing from a piece to another the initial conditions using the "General extrusion" but the model give me the error
- Expression: mod2.CI due(mod2.u2)
Extrusion coupling operator interpolation failed for at least one point: no source point found.
- Geometry: 3
- Domain: 1
- Destination coordinates.: [10.1; -0.01957691433; 0.199038782748], .... ecc..]
Any assistance is greatly appreciated.
1 Reply Last Post 19 dic 2011, 19:38 GMT-5
Hello
Posted: 1 decade ago 19 dic 2011, 19:38 GMT-5
Hi,Daniele
Have you solved your problem? Recently, I also encountered the similar error. Could you give me some suggest? thanks sincerely in advance for your help.
Yours
FM Huang
Dec. 20th,2011
- Geometry: 3
- Domain: 1
Hi,Daniele Have you solved your problem? Recently, I also encountered the similar error. Could you give me some suggest? thanks sincerely in advance for your help. Yours FM Huang Dec. 20th,2011 [QUOTE] Hi I need to model high Reynolds flow in 3D. The model is very simple: it consists of one cylinder of length 40 meters, broken into pieces of 5 meters. I would like passing from a piece to another the initial conditions using the "General extrusion" but the model give me the error Failed to evaluate expression. - Expression: mod2.CI due(mod2.u2) Failed to evaluate expression. - Expression: mod2.CI due(mod2.u2) Extrusion coupling operator interpolation failed for at least one point: no source point found. - Geometry: 3 - Domain: 1 - Destination coordinates.: [10.1; -0.01957691433; 0.199038782748], .... ecc..] Any assistance is greatly appreciated. [/QUOTE]
