30 gen 2011, 03:25 GMT-5
I believe the down() operator is as before its the variable naming that has changed. Check the operators in the 4.1 COMSOL user guide p77 under "Special Operators"
its probably something like (if you have rebuild from scratch in v4)
fluxz_ht => ht.fluxz
Turn on the "equations view", see under Preferences to help to identify the new namings
2 feb 2011, 16:14 GMT-5
Thank you, Ivar!
in v4, it is ht.dfluxz (I don't know why there is a "d" before fluxz)
What are these? built-in variables? Are there introductions about them in doc?
Thank you!
[QUOTE]
[/QUOTE]
Thank you, Ivar!
Thank you!
3 feb 2011, 06:24 GMT-5
I'm not by my Comsol station (waiting for flight) so I cannot tell exactly, but if I rememer right you have the d&u flux terms. Index your pdf doc and try a serch, but I'm not sure that all variables have been written out yet in the doc, as they were in the 3.5a doc. Note 4.1 doc is far more precise than 4.0
Magnus Ringh
COMSOL Employee
3 feb 2011, 06:49 GMT-5
To get a description and definition of a variable, check the Variables list in the Settings window for the Equation View node under the main Heat Transfer node (requires that the Equation View is activated from the View menu, which is the downward-pointing triangle in the upper-right corner of the Model Builder window):
ht.dfluxz is the "Conductive heat flux, z component".
In general, the "d" prefix is for conductive heat flux, the "a" prefix is for the convective (advective) heat flux, and the "t" prefix is for the total heat flux (essentially the sum of the convective and conductive heat fluxes).
Magnus Ringh, COMSOL
3 feb 2011, 13:08 GMT-5
Thanks Magnus, indeed the equations description is very usefull, could even be better if we could sort the variables alphabetically and copy the names to the clipboard to paste them further down in the postprocessing nodes
